copy of Accolade's Rear lip/diffuser - Bodykits Kingdom
RAwannabe
Postby RAwannabe » Fri Sep 14, 2012 5:31 pm
according to your last photo, push in the shark fin bit then you will know where to drill holes to pull it up.
chunky9
Postby chunky9 » Fri Sep 14, 2012 5:54 pm
wow what on earth is going on with the centre
but it does look sexy indeed ;)
RAwannabe
Postby RAwannabe » Fri Sep 14, 2012 6:15 pm
you also need a smaller license plate
Edmi
Postby Edmi » Fri Sep 14, 2012 8:43 pm
RAwannabe wrote:according to your last photo, push in the shark fin bit then you will know where to drill holes to pull it up.
Ok thanks man will have a look at it and apparently my number plate will fit once the lip is on, it may hang over slightly
chunky9 wrote:wow what on earth is going on with the centre but it does look sexy indeed ;)
Yeh I know it's a bit odd, sure does :) makes it look similar to the rear of the ralliart
sleepy
Postby sleepy » Tue Sep 18, 2012 8:40 pm
Looking awesome Ben! Considering getting either this or I'll try to push my luck and source a Ralliart rear bar... (any Ralliart owner want to lend their VIN? :P)
Only problem I have with this is where the reverse sensors sit on mine, which is just below the license plate.
gus0068
Postby gus0068 » Tue Sep 18, 2012 9:24 pm
My mrs has the Lancer Platinum in white this could be the go
Postby DORA_ANNE » Tue Sep 18, 2012 9:48 pm
How is the fitment going Ben ?
Edmi
Postby Edmi » Wed Sep 19, 2012 10:39 am
sleepy wrote:Looking awesome Ben! Considering getting either this or Ill try to push my luck and source a Ralliart rear bar... (any Ralliart owner want to lend their VIN? :P) Only problem I have with this is where the reverse sensors sit on mine, which is just below the license plate.
Cheers mate, It will look better once its on and the xforce exhaust is installed. Yeh i was considering the ralliart rear, until i found out the price just to get the bumper with no painting or fitting so thats why i went with this lip. Also i would have had to move or buy new reverse sensors.
gus0068 wrote:My mrs has the Lancer Platinum in white this could be the go
It finishes the rear of the lancer off nicely Chris. The stock rear in my opinion just does not do it for me.
DORA_ANNE wrote:How is the fitment going Ben ?
Its not actually on the car yet Doreen but from the photos when i trail fitted it, Its pretty good. Will post up more pics when the lip is on so u can get a better idea.
Edmi
Postby Edmi » Tue Sep 25, 2012 1:12 pm
Finally got the rear lip put on the car this morning. It looks Sick :D
I definitely recommend it, really finishes of the rear of the lancer nicely.
There are 1 or 2 gaps but there not really that noticeable.
Will post up pics when the glue dries and i can take the tape off
Edmi
copy of Accolade's Rear lip/diffuser **UPDATE**
Postby Edmi » Tue Sep 25, 2012 6:06 pm
Old and new! :)
Bags
Postby Bags » Tue Sep 25, 2012 6:36 pm
Looks good mate.
Now go get some coilovers! Haha
Edmi
Postby Edmi » Tue Sep 25, 2012 6:39 pm
thanks mate. i really want to but then i wont be able to get up the driveway. I'm risking putting a v lip on haha
Postby DORA_ANNE » Tue Sep 25, 2012 9:03 pm
Looking Good Ben :D Did they have to do anything to your exhaust to make it fit better ? And was it the panel beaters shop who installed & painted ?
Edmi
Postby Edmi » Tue Sep 25, 2012 11:40 pm
DORA_ANNE wrote:Looking Good Ben :D Did they have to do anything to your exhaust to make it fit better ? And was it the panel beaters shop who installed & painted ?
Thanks Doreen. Yea my exhaust place I go to had to cut off the exhaust pipe connecting to the muffler and fuse it back together with the tip angling down. I'm planning on getting the Xforce axle back so it is just a temp fix. If you have no tip or at least a small tip on the exhaust end it should fit fine, without modifying. Mine is 3.5'' so it was touching the bumper pretty easily.
Yea I got the lip painted and fitted at DT panels in Springvale for $400
ninja_ng
Postby ninja_ng » Wed Sep 26, 2012 12:08 pm
I got the same rear lip but from elsewhere - turned out pretty good too. I have the two small gaps too - but not noticeable unless you go right up to the car to check it out.
Users browsing this forum: No registered users and 134 guests
