2013 Ralliart Convert to Evo x Body Only
HI guys
Im thinking to buy Evo x Front bumper ,Rear bumper , and front fenders.
But some people say i need to buy rear fender as well to convert body
Is tht rite ?
Is tht rite ?
- lantourismo
- lantourismo
quachj wrote:i have seen a guy in the US do a OEM EVO X front bumper conversion and that required him buying side fenders to make it fit as the front bumper was too wide for the existing fenders i havent seen anyone do the rear one before but i would assume it would be the same as doing the front
I thought the frame it all bolts up to would be a bit wider to, that and the mounting holes would be different. If it was as simple as changing the fenders to match the bumper the rear bumper would still be harder due to the nature of the rear fenders design.
If you are going to do a rear guard change you will need 2 rear doors also.
Do you have any idea what it would cost to try to graft a set of rear guards on? I would also have a look at the sills they are probably different as well.
- lantourismo
- lantourismo
- squala
- Post Monster
If your purpose is to make people think you drive an X, then you still have the fuel filler cap to worry about, as the RA's is round and the Evo's is square.
Front bumper and fenders seem doable unless the fender mountings between RA and Evo are different (not sure), but for the rear, I can't picture how the fenders can be taken off and the wider ones fitted.
You'd probably spend thousands granted that everything can be done (labour cost in Australia is outrageous), so if I were you, I'd just buy the Evo-style front bumper and spend the rest making the RA perform closer to the X.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
i would agree with selling the RA and getting an evo
or just getting a front bumper of rainbow pen and a rear spoiler and your like 70% evo LOL!
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
- ofey
- Alumni
It's cheaper and less painful to just sell the RA and buy an EVO.
The Evo and RA do not share the same frame. So you can't just buy the ABS plastic bits of front and rear or just change fenders to get a RA to look like an Evo.
Users browsing this forum: No registered users and 110 guests
