Hey All,
the VRX lancer boot is lame to try and open. Nowhere to put fingers, heavy boot etc.
There's struts installed to keep the boot open. I'm wondering if anyone has (or knows of) an alternative , more powerful strut solution, to lift the boot open for me.
It means the boot will be harder to close, but closing is the easy part.
Thanks!
-Sean
	Better Boot Gas Struts
- seanomccool
- zedd82
I know of Harley Davidson valve springs being used before. Couldn't tell you what the spring rate is though. More or less just wound them onto the shaft of the strut. It won't pop the boot open, but will lift it a little higher so you can put your fingers underneath. The way the hinges are designed there isn't really a way to pop the boot open.
						- zedd82
You don't want to go too long on the springs otherwise you will have trouble closing the boot. There is very little of the shaft of the strut that is extended past the body of it when the boot is closed and the spring has to sit on/around the shaft.
IMO the main design floor is unlike the sports back model the number plate is not on the tail, a nice and easy place to lift from.
I was actually thinking of some kind of strap that is bolted inside the boot and comes out say 10 cm in the center, enough to hold onto but not enough to flap around too much and wreck the paint work.
- seanomccool
- seanomccool
