Ralliart / evo bonnet vents on N/A lancer bonnet
Maddy.b
Postby Maddy.b » Mon Feb 26, 2018 5:49 pm
Hi , I’m just wondering if anyone has ever cut a N/A bonnet to fit Ralliart/ Evo vents on it . Would it work? or no?
Thanks
2008 VRX Lancer :D :)
Re: Ralliart / evo bonnet vents on N/A lancer bonnet
Postby aspir3 » Mon Feb 26, 2018 5:59 pm
It won't work
benyamin
Postby benyamin » Mon Feb 26, 2018 7:25 pm
They're structurally different and use different materials. This thread is probably worth a read...
Another idea would be to make a faux RA / Evo bonnet, i.e. non-functional, but it would be a lot of work.
Maddy.b
Postby Maddy.b » Tue Feb 27, 2018 5:41 pm
Oh ok, well thanks !
Postby Lancer1993 » Tue Feb 27, 2018 9:47 pm
You could always do like Clarkson did in Bolivia!
Or this...
benyamin
Postby benyamin » Tue Feb 27, 2018 10:08 pm
:lolhit:
~lynel~
Postby ~lynel~ » Wed Feb 28, 2018 5:54 am
Whats a 2nd hand ra bonnet run from a wreckers?
2013 ralliart
Quismiff
Postby Quismiff » Wed Feb 28, 2018 7:50 am
There was an RA bonnet on gumtree a while back in SA, they only wanted only a couple of hundred for it...
2007 MY08 VR-X (cj-red)
Postby aspir3 » Wed Feb 28, 2018 9:43 am
A good second hand evo/ralliart bonnet will be around $1,000
Quismiff
Postby Quismiff » Wed Feb 28, 2018 9:52 am
Depending on where you are this could be an option?
It is carbon Fibre though so look at it very carefully if you consider it/it is still available.
Maddy.b
Postby Maddy.b » Wed Feb 28, 2018 10:22 pm
Thanks, I’m trying to find one that’s not ridiculously expensive ahah
ReeceCozaa
Postby ReeceCozaa » Thu Mar 01, 2018 10:36 am
Yeah the massive bummer about the bonnet is it’s price tag, I’ve seen some for 1000 bucks too
We are all in it for the fun!
Postby Lancer1993 » Fri Mar 02, 2018 8:29 pm
Maybe get a cheap stock CJ one from the wreckers and see if it can be tastefully modified... just do a better job than Clarkson!
Maddy.b
Postby Maddy.b » Sun Mar 04, 2018 7:22 pm
Yeah good idea lancer1993
Postby bumblebee » Fri Jun 28, 2019 9:15 pm
Go have a chat to a custom hot rod shop or similar , these guys can do this kind of work in their sleep
I remember chasing this up with a few custom hot rod shops up north and was from memory quoted only a few hundred to get the job done.
I also happen to have met a young man who took to his bonnet himself and dropped in some Air scoops.
It doesn't look too bad I guess
Unfortunately they are mounted out wide where they don't really serve much purpose
Looks ok though to look at though
