Where to buy aftermarket stuff?
Local Victorian State News, Meets, Cruises, Information & Talk.
MrMuppet
Postby MrMuppet » Fri Sep 30, 2011 9:52 am
your best options are to check the for sale section, or contact Ofey.
And keep a lookout for the Group Buys that happen from time to time.
Good luck
My CJ is the best. "Why??" It has 3 DVD Players :)
megatron
Postby megatron » Fri Sep 30, 2011 11:21 am
US online stores eg. lancershop, MAP etc etc
Postby ofey » Fri Sep 30, 2011 11:27 am
US$100 for postage is not expensive.
Postage is a very expensive game because of fuel levies implemented by airlines.
Here are some thoughts, why don't you try calculating how much it costs to send the same item from Australia to USA? Use the Auspost calculator and factor in the size and weight.
It's usually about A$80-90 to get a box of stuff from Aus -> USA by Air Mail.
There are no local companies who will carry aftermarket parts cheaply.
Australia does not have enough buying power to even sell at the prices the Americans get it at. So alot of things you still need to buy via eBay or the like from the USA.
PYLee
Postby PYLee » Fri Sep 30, 2011 11:49 am
shall we have a little group buy from MAPerformance ? :)
Lancer Evolution 10MR
kakar0t
Postby kakar0t » Fri Sep 30, 2011 3:51 pm
This thread is very useful for an aspiring modbug like myself, thanks guys! Online it is, now where to start? Lighting mods ftw :D
PYLee
Postby PYLee » Fri Sep 30, 2011 4:03 pm
be sure to give MAPerformance an email , they should be able to source parts for you, their website aren't the best
Postby ofey » Fri Sep 30, 2011 4:11 pm
Not all the time.
A GTS is equivalent to a VRX.
But as you know the RA and the NA Lancers share the same chassis.
So only certain parts.
If you're refering to an air intake box, it may not be tuned for a turbo-ed car. Obviously the turbo model needs more.
But the same panel filters are used in the NA->RA->Evo.
Postby ofey » Fri Sep 30, 2011 4:12 pm
kakar0t wrote:This thread is very useful for an aspiring modbug like myself, thanks guys! Online it is, now where to start? Lighting mods ftw :D
for good LED lighting for things like in-car or grill lighting, check out Oznium.
Slash
Postby Slash » Fri Sep 30, 2011 4:31 pm
All you really need is a good drop in filter.. I know evos with 280wkw still using the stock box and ralliart panel filter...
I run 220wkw i have a panel filter, just switched it to a cosworth filter, but still a drop in..
cheap and easy performance
Return to “Victoria”
