	2008-2010 Mitsubishi Lancer Halo Projector Headlights
Projector headlights provide an intensely concentrated light beam with an innovative design that gives your car a unique look. For only a fraction of the cost of OEM Headlights, you can replace your old faded or damaged headlights with eye catching projector headlights. Not only do the new lights refresh the look of your car they are also brighter, making driving in the night and unlit streets a lot safer. The Headlights are securely mounted using the original screws & nuts of the OEM parts. New CCFL (Cold Cathode Flourescent Lamp) halos are brighter than the standard halo. Boasting lower power consumption and longer life span, these CCFL halos will last the life of your vehicle.
[url]
http://www.k2motor.com/2008-2010-mitsub ... -blue.html[/url]
Feature:
- Fits: 2008-2010 Mitsubishi Lancer Evo X
- Blue Inner Halo Circle
- Ultrabright CCFL halo projector design. Some wiring required.
- If you are unsure about installing automotive accessories by yourself we recommend consulting a body shop.
- Dot/Sae approved headlights made by approved and certified manufacturer to ensure quality & fitment.
http://www.youtube.com/user/Specdtuning ... jIwA5YLKg0
						[url]
Feature:
How to Install Projector Headlights for 2008-2010 Mitsubishi Lancer Evolution
1. After the hood is open, remove the weather shield above the radiator by removing (5) clips that fasten it down.
2. Underneath the car, at the edge of the front bumper, there are (12) clips and (6) bolts that needs to be removed.
3. Inside of each wheel well, there are (3) clips and (1) bolt right across from the tire.
4. Hidden behind the top of the bumper, behind the emblem, there is (1) clip, (1) harness, (1) bolt; that needs to taken out and disconnected.
5. On the top of the bumper there (4) bolts that hold down the front bumper.
6. And another (2) bolts right in front will compete the removal of the front bumper.
7. Once the bumper is off; pull up the white fluid container to get to the light bulb harness.
8. Now you can remove the (4) bolts that are holding the headlight in position.
9. Gently wiggle out the headlights, and plug in any resistors if applicable. (negative with negative wire)
10. Place back the projectors to it's original location. Replace all the bolts for the headlights by following the steps from (8-1) in reverse.
11. The installation is complete.
