Vibrating rear view mirror
squala
Postby squala » Tue Feb 16, 2010 1:18 am
Has anyone else experienced this? During acceleration from rest or on not-so-good roads (which are common in Melbourne), it just wiggles. It's quite bothersome and could make me dizzy during a bad day.
I'm sure it can get replaced by warranty but I'm just sceptic the new part may experience the same problem through time. A fix would be much better.
I've passed the same roads in a '96 Corolla and its mirror never had vibrating issues. So far, this is the only quality niggle I've come across the Snob.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
LZY_EYE
Postby LZY_EYE » Tue Feb 16, 2010 4:13 am
The only rattle I have inside my car is the rear demister button. So I am quite confident that replacing the mirror would help. Have you tried finding exactly the noise comes from?? A little grease might fix the noises...
SIR-VRX
Postby SIR-VRX » Tue Feb 16, 2010 4:17 am
Lube it up haha
Graham
Postby Graham » Tue Feb 16, 2010 5:28 am
I haven't had mine vibrate or anything like that, have you tried firmly holding the mirror when you hear the vibrations to try and isolate it? does it still happen if you hold it?
If it stops it could be the mirror, otherwise it could be something else
Daily Driver: Yamaha R1
tadz0rz
Postby tadz0rz » Tue Feb 16, 2010 6:56 am
After thrashing the crap outa the subs, i do notice mine does shake, and not because of the subs being on.
My mums car had the problem that it never stayed in the same place and when she took it for a service they had found that the mounting screw had become loose.
I dont know if the lancer has a screw type setup for securing the mirror, but it might be something to check...
Blakey
Postby Blakey » Tue Feb 16, 2010 7:28 am
he never said its making sounds, hes sayings its moving, why not move it around a bit see if its loose.
JaCe
Postby JaCe » Tue Feb 16, 2010 12:06 pm
LOL mine only vibrates with the sub. No looser than before.
LZY_EYE
Postby LZY_EYE » Tue Feb 16, 2010 12:12 pm
Mine too JaCe.
To the point I can hardly see anything!
tryg
Postby tryg » Tue Feb 16, 2010 6:58 pm
I'm with the rest, mine shakes and vibes under massive sub-woofer loading, but is fine even after all of that...
Ral1rt
Postby Ral1rt » Tue Feb 16, 2010 9:05 pm
Mine vibrates on idle with my stupidly loud exhaust ;-) Like it should
Owner: Matt Stewart
09 Ralliart tuned at MPC
13.22 @ 106mph Australia's 2nd fastest Ralliart. (Ill get you captain :-) )
R4LLI4RT
Postby R4LLI4RT » Tue Feb 16, 2010 9:09 pm
mines sweet only when the stereo is on does it vibrate - your maybe just loose where it meets to the bracket.
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
squala
Postby squala » Wed Feb 17, 2010 1:18 am
Sorry for the misunderstanding, but by vibrating, I meant shaking, not noise. I'm just disappointed this is happening in a car less than a year old. I'll have it checked during the next service.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Josh_Emerton
Postby Josh_Emerton » Wed Feb 17, 2010 7:50 am
My mirrors (all of them) hate my music. But when music not on, they fine.
Return to “ClubCJ Talk”
