Keep this in mind.
P26 red requires a special neutral grey basecoat for the colour to be applied properly.
The process is actually classed as a 3 layer pearl.
-Grey base
-P26 red which is actually has no metallic tinters in it. Only pearls and solids. This colour is a grade 3 colour and is the most expensive.
-Then clear coat.
I know this because I painted my own body kit.
My Father also teached automotive spray painting for 24years.
This is probably why you have been quoted sight unseen, around $200-$250 per loose part.
Painting Body Kits
