	Maximum legal temperature for HID??
Hello guys,
I was wondering what is the maximum legal temperature for HIDs for WA?
I was thinking of getting a 6000k ones but some of my friend says that the maximum legal temperature for WA is 5000k? (he was unsure of it too)
Does anyone knows whether 6000k is still considered legal for WA?
Or have a link to where I can search for this information?
I don't think there is a maximum legal temperature as HID's are frowned upon in reflector headlights so that alone could be worth a defect if the officer knows his stuff and wants to give you a sticker
Anything 6000k below should be fine though as it isn't too blue
Daily Driver: Yamaha R1
Oh and try and keep HID discussion in this topic
http://clubcj.net/viewtopic.php?t=5406
I've had 6000k's in my car for probably 8-10 months, cops have never said anything about it.
I got lucky once though! shortly after I hit a kangaroo (which smashed my headlight) I was pulled over and they did the quick check of the car and somehow he didnt notice that my headlight was out
that's probably the closest legal trouble I've had with anything related to my headlights
- BR14AN
 - Lancer Ralliart
my understanding is 6000k but who knows
i was driving behind a cop in the night down a steep heal getting my lights right in his mirror (just to see if hed pull me over) no response haha and im on my Ps so i think youll be fine
p.s I LOVE MY HIDs (6000k 35w)
						HIDs are illegal in cars with reflector housings and where the HIDs are OEM-fitted.
That being said all OEM globes you'll find are 4300K and its the optics of the projector lenses that gives them a bluey tinge depending on the angle.
If you are going to do HIDs (keeping in mind they are illegal) then go for the 4300K as these are the easiest on your eyes, produce less glare and have the largest 'range'...
smithsy wrote:HIDs are illegal in cars with reflector housings and where the HIDs are OEM-fitted.
My uncles 2008 VRX 7 seater Outlander (the non lancer fronted model) came from factory with HID's in reflector housing headlights, also remember that it is a ADR requirement that HID equipped cars have to have headlight washers as well
Red EVOX wrote:smithsy wrote:HIDs are illegal in cars with reflector housings and where the HIDs are OEM-fitted.
there are 2 types of HID's, there is a speacial, type of HID that can go in a Reflector housing, but the housing is a HID reflector housing, not a halogen. if you look at the actual reflector they will be different to halogen reflectors,
the 2 types are the special type of one, has a metal, blocker built into the bulb.on one side of the bulb, but it still requires to be in a proper housing,
the other type is the general usual HID, that everyone knows about.
dtrial wrote:sorry newb question: whats a headlight washer? or can anyone please give me a link/pic of it?
Tried looking at yahoo but all they give is just "washing the headlight" image
the headlight washer, is a high pressure, sprayer that is in the bumper of cars that have HID's, its an ADR requirement.
they are to remove dirt from the headlight housing to prevent stray glarey light coming from refraction off the dirt.
they are usualy bhind a little square under the HID projecton on the front bumper, they pop out when used
The head light washes only come on in my Aspire when the headlights are on and I wash the windscreen.
As Blake said they sit behind a rectangle piece of plastic that sits flush with the bumper when not being used. Once you active the windscreen washes they are pushed out from the bumper and spray windscreen washer fluid on to the light lenses. They are returned to the bumper with a spring. They are easy enough to pull out with your fingers.
