Remove/install rear vision mirror covers
Did a search and couldn't find anything - anyone have info (preferably with pics ) ?
Hey Shane - worked it out !!
Removing - start at the lower edge nearest the door.... grip cover ( fingernails help ) and pull down. Corner should come away from mirror housing. Work your way outwards from the door, along bottom edge. Then lift cover (gently !! ) upwards. Voila !!! Cover removed.
Replacing - line up the 3 "fingers" along the lower edge of the cover with the slots in the mirror housing. Press the cover inwards until the cover engages fully on the housing.
Happy ...happy !!!
Happy ...happy !!!
- ofey
- Alumni
WTR: Have you considered just looking at the wiring that's used by those who have the folding mirror thing? There are some wires we tap from the fuse box on the pax side behind the fuse box, just use those quick connectors to tap onto the same signal lines.
If you need the instruction manual in PDF, PM me your email address.
- ofey
- Alumni
Far neater solution though. To connect to the side signal indicators, there is no rubber hosing to carry it across from the door and secondly, when you open your door, you'll have this wire hanging across.
I still think quick connectors onto the fuse box as per the folding mirrors is a far more elegant solution.
