Relay comes with horn not harness kit.
My right/left references are relative to your position when you are standing in front of car facing the engine, as when you are working on the front of the car.
VRX_Pete wrote:JaCe, so what's your thoughts, well worth the trouble?
Since you got the TM80/2 - that's going to be a 500 & 410 harmonized tone plus the left over lancer's other horn (which is may be the 500) - hence the too high pitch noise. Try putting the removed one back in to even things out and have the original dual harmonized tone.
Me, really considering the 300Hz truck one for a triple harmonized tone of 300/410/500 and a bit of oompf.
