Hey all,
Just wondering if you guys have the same issue.
I'm referring to the dark grey fabric/plastic liner that surrounds the left and right sides of the boot. I noticed that on the left side, where there appears to be a cut-out pattern, it's sagging down a lot and is not flushed at all.
The nearest plastic screw isn't doing a particularly good job either, as the hole has torn so there's not much grip anymore.
I only spotted it as I was trying to see where I could place a strip of LEDs.
I'll take a photo once the weather clears.
Cheers,
Danny
Boot Liner Issue?
Well once you put the pics up I might be able to help. I had my whole interior stripped out a while ago, then I put it back in, just for sh!ts and giggles
But I think my boot setup is a little different to yours though.
Jase
Jase
Enkei - HKS - Turbosmart - Cosworth- TMW - Defi - DeatschWerks
Going through the LED thread, I spotted Hoge's photo:
If you look at the liner, it looks pretty warped. The sag point should really be flushed to the top of boot, and fitting tightly around some electrical cables.
I guess that suggests it's a "problem" for other cars. It doesn't really affect anything, but it does seem out of place and is a quality issue.
I'll take a photo tomorrow anyway.
