well im just wanting to know whats better.
a single EF-S 18-135mm f/3.5-5.6 IS lens
or 2 lens's
EF-S 18-55mm f/3.5-5.6 IS lens
EF-S 55-250mm f/4-5.6 IS lens
what is better for the money? both are the same cost all up. roughtly
Whats a Better Camera Lens?
Are any of them VR? Other things to keep in mind are plastic vs metal mounting points (broken plastic mounts aren't usually covered by warranty) weight etc (heavier can actually be better for lenses - stability and balance). If you can play with them, check the zoom mechanics, cheaper lenses can be a lot less smooth.
But otherwise, I agree with Kang ... two lenses seems like a cool idea, but you'll quickly get tired of changing. Also consider that every time you change, you run the risk of getting dust up in there. 135 might be a little restrictive ... it's always a balancing act. Lenses are important though and more money is usually better. Out of those choices, I'd take the 18-135.
- vlad_the_impaler
I can give you some practical advise although my expirience is with Nikon cameras not Canon. 18-55 and 55-250 are entry level lenses so for that reason they are a bit cheaper. If you look at the lens mount you'll notice that it's plastic. Well I have some bad expirince with that plastic cos it's fragile. For 18-135mm it's should be made from alloy so it's more reliable.
here's some good source for reading:
http://www.kenrockwell.com/canon/lenses/18-55mm-is.htm
http://www.kenrockwell.com/canon/lenses/55-250mm-is.htm
http://www.kenrockwell.com/canon/lenses/18-135mm.htm
- Mixedmotorsportmedia
- jolly_tas
- Lancer Ralliart
I can't give you any help with what lens to choose but I looked into all that when I was buying a camera and just decided an ultra zoom was more practical for me. It doesn't quite have all the bells and whistles of an SLR but still has full manual aperture and shutter (1/1000 - 16 secs) with the bonus of being able to go from 3cm super macro to 38-380mm without changing lenses.
Different strokes for different folks, but from what I did research, go for the single lens pack. Less hassle, and as Draevon said, less chance of getting dirt inside.
