	WTB: Stock Evo X BOV
Just wanted to see if any one has there stock EVO X BOV laying around for sale.
Cheers
						Cheers
- ofey
 - Alumni
Maybe they want to keep it stock i.e. Mitsu OEM?
Also from a material POV, The Evo ones are metallic body while the RA ones are plastic? Better quality then?
No mate, sounds no different, just gained better smoother power when I combined it with the wastegate upgrade so it holds boost on longer and stronger now, went from 25PSI back to around 20PSI & atwkw went up and the power curve smoothed out, it is in the RA performance dyno graphs if you interested
