Weird things with the maintenance settings
- theforceunleashed
Hi all...
I have a strange issue with my VRX.
It was set for next maintenance at 30,000km.
I am only on 14,000km, and all of a sudden when I started my car up, the display changed to ---- and then "periodical maintenance" appeared on the screen, and the MMCS also came up showing something about maintenance.
I checked the info/maintenance, and it had my last service date of 30/9/10.
Has anyone had this experience?
Also sometimes when I start the car, even on a day with no rain, the wipers turn on for one wipe, and then turn off.
Is my car possessed!
- Hitman
- Lancer Ralliart
If you have the auto wipers on, they are supposed to give 1 wipe when the car starts to clear anything from the sensors so they can work properly. That's what Mitsubishi told me.
As I don't want to get scratches in the glass I leave the auto wipers off unless it is a rainy day, then I leave them on to do there thing.
- ofey
- Alumni
The wipers sometime sweep because of dust. When driving through a dust storm the wipers will go as well.
As for the periodical maintenance you have to check the intervals. If it happens all the time and you've checked that your interval says every 15000, it could be you have a real fault in the car that it's alerting you to.
- theforceunleashed
Ok, So the wipers thing is normal.
With the middle display saying Periodic Interval coming up the the display it is weird, because this morning I got in the car and it have 30,000km for next service or 8/11. So I checked on the MMCS and it only had last time I had the service done. Which was at 14,000km. I changed it to 8/8/2011, but still comes up on the middle display Periodic Interval, and then has the oil can sign. I checked the oil, and its fine, car isn't leaking.
I was thinking of going to the service center where I had it done (knox) and get them to check it out.
- The X
theforceunleashed wrote:Hi all...
The service reminder seems not to have been reset to 30,000 by whomever did your service. It needs to be done with the MUT or on the console, instructions here http://clubcj.net/viewtopic.php?t=604
I'm not usre if the MMSC can control the ETACS service reminders. I'm thinking the MMSC is just a courtesy reminder rather than a control of the ETACS schedule.
theforceunleashed wrote:Periodic Interval, and then has the oil can sign. I checked the oil, and its fine, car isn't leaking.
Um oil can is not a good sign. Oil pressure issue perhaps. Did they change the oil filter out? LOL. Best to take it to Knox and ask them to look into it.
Mine started doing service reminder when I hit 14,000 (mine was due 15,000). I'll be resetting my service reminder tonight as I serviced it today.
Hitman wrote:If you have the auto wipers on, they are supposed to give 1 wipe when the car starts to clear anything from the sensors so they can work properly. That's what Mitsubishi told me.
Bulldust! The sensor "sees". What it should see is water droplets and the way it refracts light. What does happen sometimes is dust or sometimes the way it catches a ray of sunlight and that's enough to trigger it.
I have my sensitivity set to medium at all times and have this event occur very rarely.
- Goose003
Hey everhyone, iv got pretty much the same problem Jen's got, service id due in 500 k's and the "routine maintenance required" message pops up. Should I just wait for 1500? or go for an early service?
DBA Rotors W EBC Pads
UR Struts & Eibach Pro Kits
Alpine Head & Hertz Splits W/ Blackvue DRG500
Takeda SRI & Custom Exhaust
- Tin_Pusher
I got that too with the first service and thought it was an early reminder, but don't recall seeing it before the 15,000k one.
Right now, try as I might, I can't get the service reminder to move on from 30000k to 45000k. I had the 15000k service done at a Preston Motors branch (Tullamarine) but they didn't reset the reminder. I don't think they are as familiar with Mitsubishi as PMR. I managed to reset it to 30000k myself afterwards, but having just had that service now, I can't move it on any further.
- Latino_Ralliart
Sorry to bring back an old topic. But as soon as my car hit 1100km I get the routine maintenance required. However the first service is due at 1500km or in 2 more months.
Has it been agreed this is an early reminder? Kind of annoying as it appears everytime the car turns on however only for a split second.
- Latino_Ralliart
