Rear window tinted only on new cars.
Postby SAM-24A » Fri Mar 18, 2011 8:34 pm
Your always "Wrong Ron" :lolhit:
Yes your right,
IR generates Heat as in Infra-red Heat Lamps applied to limbs to promote the healing process.
UV causes Burn as in Sunburn from baking on the beach.
However UV, when captured / gathered in an enclosed environment (inside a closed vehicle) will also generate Heat.
So both are as bad as each other in terms of occupant discomfort and deterioration of internal materials and surfaces within the vehicle.
my take: be it right, wrong or waffle. *loco*
Sam *brick*
That's why I don't ride Bikes, Ron :haha:
WTR
Postby WTR » Fri Mar 18, 2011 8:37 pm
Yum !!!! Waffles ..........
Postby SAM-24A » Fri Mar 18, 2011 8:40 pm
Your more of a Hmmmm "Homer Dounuts Man" aren't you Ron.
WTR
Postby WTR » Fri Mar 18, 2011 8:41 pm
Nah ...... but I do like a good BBQ, Sam ..... 8)
Postby SAM-24A » Fri Mar 18, 2011 8:57 pm
Well Then, you better talk to Troy, he cooked everything you ate at the Centennial Park BBQ.
