Sold - Evo X Turbo
if you are considering this turbo upgrade for your RA, here is the full list that you'll need (and prices from misti parts.net and used prices)
Part Part # CONDITION VALUE
Turbo 1515A183 (1515A198)
Exhaust Manifold 1555A476 USED $150.00
Exhaust Stud x2 MN119784 NEW $15.54
Turbo Outlet Pipe 1515A150 NEW $49.64
Turbo to manifold gasket 1515A184 NEW $35.19
Turbo to O2 housing gasket 1555A289 NEW $32.21
O2 Housing 1555A423 USED $90.00
Oil Return Line 1225A181
Coolant return pipe 1310A469
Coolant feed pipe 1310A577
Coolant banjo bolt MF650114 NEW $11.76
Coolant banjo bolt gasket MF660065 NEW $3.04
Inlet Elbow 1542A042
Inlet Elbow Gasket 1515A053
Downpipe 1570B095 USED $100.00
Sub total $387.38
Recommended but not required to work
O2 housing bracket 1555A320 NEW $15.23
Oil Return line gasket MD194403 NEW $1.22
Compressor housing bracket 1515A166 NEW $15.23
Compressor housing bracket bolt MF140264 NEW $1.78
Compressor housing bracket bolt MF140260 NEW $1.04
Turbo outlet pipe gasket MR281085 NEW $3.71
Subtotal $38.21
GRAND TOTAL $425.59
Sub total $387.38
Subtotal $38.21
GRAND TOTAL $425.59
we are fascinated by that which can destroy us...
