Postby ofey » Tue Feb 08, 2011 2:14 pm
			Depends how much liability you will put on them. Say they F**K up the baking?  Baking too long and the plastic starts to warp, it will cost them A$300+ to replace that side.
It's great if there's someone out there who can do these things but you must accept that it may not be a perfect job. It's not their car. It's a job.
I strongly suggest this is a DIY thing.  It's literally bake till glue softens, put on the rings, clip back the lens melt glue reform seal, put back onto car. Patience is the key.  You need a lot of time as you slowly increase the heat till the glue melts.
BC BR-type Coilovers | UR + Whiteline  Bars
