I must check to see if the sensor is indeed on the dash, can't say I have noticed a sensor there. I guess cover the windscreen sensor and if the lights go on then you will know. Anyhow the auto lights and wipers are great, no
Need to touch the switches unless I put the fog lamps on during foggy conditions of course. Not that the fog lamps really do much. Having the headlamps come on when I drive in a carpark or tunnel is a great safety thing to have and I feel all makes and models should have the auto lights as a standard feature. I wouldn't be suprised sometime down the track where all cars will have DRL'S fitted as a standard feature as well
Dusk Sensing Headlight
I asked a previous member on here before,
He said the light and rain sensors were in the part behind the mirror.
The sensor in the dash is a sunlight sensor. When you drive your car into a tunnel/at night even in the base models, you will notice that the SPEEDO lights will come on (regardless or whether your lights are off). However in the day the lighting is off.
This is my understanding of the sensors. The auto-light sensor is in the rain sensor - and it can sense ahead of the car? Reason why the lights don't come on in short but dark tunnels.
Yeah the angle of the sensor is pointing towards the sky more so in a short tunnel the sensor is still seeing light. The camrys are ultra sensitive. There lights will come on even going under a underpass that maybe 10 meters in length. I don't take much notice about the sensor now long as the lights are on when it's dark that's the main priority
ofey wrote:Relay for locking unlocking?
Ops sorry. What I meant was http://clubcj.net/viewtopic.php?t=7455& ... y&start=30
