Hey guys
i just had a problem, i turn my car on at train station car park drove it like less than 100m, i stopped i put it on Neutral and shift to gear one ( its Manual) and it won;t go in to any gear and i start to smell very weird smell soo i pushed it on the side of the road turn it off. after 5 minutes i put it on reverse and it just jumped and i could shift normal after that.
im still worried i don;t know what was wrong can any one please tell me what could be the problem?
its Lancer Vr 2009 and i have done 37ks
Can't Shift gear :(
- Josh_Emerton
The failure to change gear sounded like the gear shift cable bracket, under the battery area. I've had that unbolt on me before, thats the ONLY thing thats stopped me from changing gear. Ever. And I was the first CJ in Australia to blow the clutch >.< all it did then was extreme high revving no matter what and wierd smell, no gear change problems.
- craigeth
- Lancer VR/GT
Harry you're posting again! Haha.
www.twentythreeframes.com
I think this is a selector problem. It might have selected 2 gears therefore locking up the gearbox which caused the clutch to slip and burn.
I would definitely get Mitsubishi to check it out and demand the gearbox is removed for inspection and the clutch replaced. This should all be covered under warranty.
