help !anyone have the wiriing diagram
FOR THE lancer CY4A
THE Wiring diagram that has speed signal and rev signal in it ! thanks !!!!!!!!
help! !anyone have the wiriing diagram
- ofey
- Alumni
OK I'll bite.
You said on chat last night you spent a whole day looking and could not find the wiring diagram for the car.
Let me google that for you.
First link is from New Zealand! And you're from? New Zealand!!
Problem solved.
Look through the wiring diagrams and you should find what you need.
Or do you need someone to do that for you too?
Let us know. Someone else will help.
But the sooner you learn to "fish" the better for you really.
Problem solved.
- Speedie
2008 MITSUBISHI LANCER 4DR SEDAN WITH 2.0L ENGINE AND ROCKFORD FOSGATE PUNCH® 9-SPEAKER AUDIO SYSTEM
Speed Sense
Wire Color BROWN/WHITE
Polarity (AC)
Location AT ECM MODULE ON DRIVER SIDE OF AIRCLEANER ASSEMBLY
Pin # 48 PIN PLUG PIN 10
Tach
Wire Color GREEN/WHITE
Polarity (AC)
Pin # 64 PIN PLUG PIN 2
This information is from Victory Technologies, Inc
Speed Sense
Polarity (AC)
Tach
Polarity (AC)
- jasonkira
ofey wrote:OK Ill bite. You said on chat last night you spent a whole day looking and could not find the wiring diagram for the car. Let me google that for you. First link is from New Zealand! And youre from? New Zealand!! Problem solved. Look through the wiring diagrams and you should find what you need. Or do you need someone to do that for you too? Let us know. Someone else will help. But the sooner you learn to fish the better for you really.
i ask all around the friends la...they say my car is too new..they told me to find the wiring diagram...have been google it...~keep looking ,keep searching.. diu,spend so much time~
- jasonkira
Speedie wrote:2008 MITSUBISHI LANCER 4DR SEDAN WITH 2.0L ENGINE AND ROCKFORD FOSGATE PUNCH® 9-SPEAKER AUDIO SYSTEM Speed Sense Wire Color BROWN/WHITE Polarity (AC) Location AT ECM MODULE ON DRIVER SIDE OF AIRCLEANER ASSEMBLY Pin # 48 PIN PLUG PIN 10 Tach Wire Color GREEN/WHITE Polarity (AC) Location AT ECM MODULE ON DRIVER SIDE OF AIRCLEANER ASSEMBLY Pin # 64 PIN PLUG PIN 2 This information is from Victory Technologies, Inc
i think this information might help~ hanks for posting this
