Just recently rotated my wheels and the drivers side rear wheel one of studs the spline end of it has come out and not allowing the wheel nut to free itself instead its stuck on the stud. Now i cant get my wheel off and to get it off I have to damage the rim.
I work for Nissan this isn't very common but when I went next door to Mitsi they say that the CJ's are common for it and easily corrode if not greased regularly so please check your wheel nuts as this can be a pain.
Does anyone else have this problem?
Snapping Wheel Nuts
- The X
Not aware that anyone else has had that issue. Unless the nuts you have are of a particular metal that has reacted and fused with the thread?!
Can't you just rattle gun it off?
Troy's suggestion seems to be the only option left.
Raise Car on Hoist .... Weld the Stud Head at the rear of the Hub.
Fit Socket & Remove the Nut.
As Shane mentioned:
Generally the Stud simply Shears in half, which would have been a much easier fix.
I've seen it happen a few times at work ..... and mostly due to a Bone-Brain mechanic with an incorrectly set Rattle Gun.
Most Rattle Guns have a Torque Setting Dial ....
You really should "AVOID" - "DISCOURAGE" someone using a Rattle Gun on your Wheels ....
They're "NOT NECESSARY" .... Unless the user is Proficient & Understanding of their Proper Use.
Sam ....
As Shane mentioned:
Usually when it is over tightened with a rattle gun it wrecks the spline.
Sam ....
Sam .....
