So here's a thread to list any good car related stuff or tech stuff/toys you might be interested in.... remember, to factor in postage from the US (so it may not be cheaper than getting it locally).... and yes the Aussie dollar is below parity, but remember it's way better than it was when it was hanging around in the mid-seventy cents range.... so it's still good a good time to buy internationally as long as the savings is there..
Do your research before buying and dont be impulsive!
Please remember everything is in US dollars and also bear in mind the timezone difference, so thier Friday is partially into our Saturday.
Also for those buying tech toys, you will have a US style power plug! That can be solved by buying a travel adaptor or getting a sparky to shop off the plug and replace it with an AU style one.
Check voltages!!!! If the device uses an external "brick" style transformer - usually they can take international range of voltages from the USA 110v to the AU 240v. If the device cannot take international range of voltages, don't bother, it will be useless to you in AU.
