Hi Guys,
I need to change the pads on my RA just wondering who has changed theirs and whats the best ones to use.
Im a value for money kind of person.
Ive called up Mitsu and they want $150 for the front and $130 for the rear.
I did some research and found that the fronts (DB1223) can be about $75 to $90 for a pair and the same for the rear (DB1464)
Any thoughts or refrences would be good.
Thanks,
RA BRAKE PADS
RA BRAKE PADS
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
- ijustatecurry
I also bought QRM from gslrallysport for my Skyline. A1RM is the more track oriented pad - I got HPX which had a lower max temp but better cold friction.
They were excellent value, I used them for about 3 years including 1 track day and they were still good when I sold the car. They were cheap, worked well, long lasting, never squealed, not dusty... can't think what else you can want from a brake pad.
I highly recommend them and would buy them again for the Ralliart for sure.
debonaire wrote:I also bought QRM from gslrallysport for my Skyline. A1RM is the more track oriented pad - I got HPX which had a lower max temp but better cold friction. They were excellent value, I used them for about 3 years including 1 track day and they were still good when I sold the car. They were cheap, worked well, long lasting, never squealed, not dusty... cant think what else you can want from a brake pad. I highly recommend them and would buy them again for the Ralliart for sure.
could not agree more
