skygunner wrote:My pedometer is approaching 90k.
ROFL IRL
skygunner wrote:jimmytim wrote:mmm...correct me if I'm wrong, but doesn't the cj uses timing chain instead?
A 90k service should only cost around $200 if nothing is wrong with the car, i.e. nothing needs replacing, other fluids or parts.
actually if you look at the logbook by Mitsubishi, there's quite a few things needed to replace, e/g/ transmission fluid, brake fluid, spark plug etc ..
empror wrote:in reference to the timing belt/timing chain mentions earlier, MY08 VR 4dr 5spd m/t is still a timing belt toowhat kind of costs have you guys found for timing belt changes at different mechanics?
DORA_ANNE wrote:Bit confused here .... My Mitsubishi service guy told me that my 08 VR CVT Dosent have a Timing chain it has a Timing belt in which dosent need to be replaced .... So are the manual Lancers the same
