LOWER MY SX 2011
LOWER MY SX 2011
Hi Guys, I want to lower my SX Lancer what spring would you suggest. I want to go about 25mm around. I want to a reasonable ride. Can't wait to hear your suggestions
The closest you're going to get to a 25mm drop all around is the WORKS lowering springs which drop 1.1 inch all round. Check out the link below:
http://www.autocityimports.com//2008-mi ... 72d6adae9b
Lovells Front HFS-506
Lovells Rear CRL-81SL
Sport Lows - 25mm
http://www.lovellsauto.com.au/docs/cat_passcomm11.pdf
Sport Lows - 25mm
seeing everyone's screaming I'll put my ear plugs in before I type this..............................................
Anyhow I have pedders sport rider springs cost around $650 fitted and it's supposed to be a 35mm drop.
Great handling, the ride is more rougher but thats to be expected.
Personally I'm happy with the height, but not the ride.
- ofey
- Alumni
Cheapest is still to scan eBay and buy from the US. If you're forced to buy it in Australia, get it from Eibach's Australian distributor:
http://www.eibach.com.au/
Also there is now Eibach Direct
http://www.eibachdirect.com/p/1146807/pro-kit-.html
