Jack Stands - Advice Needed
alterego13
Postby alterego13 » Mon Apr 16, 2012 11:21 am
Yes...the undertray is where i got stuck :(
LZY_EYE
Postby LZY_EYE » Mon Apr 16, 2012 11:43 am
I use a set of these... http://caravansplus.com.au/catalog/prod ... ts_id=2328
I can get to the undertray etc, and change oil.. Easy enough to get the car onto them as long as it isn't too low. I actually bought them to make it easier to get my jack under the car, but work well as ramps too :)
alterego13
Postby alterego13 » Mon Apr 16, 2012 3:44 pm
Have no access to such geograpgical features...
and standard gutter on side of road?? O.0 You want to kill me or what? :P
LZY_EYE
Postby LZY_EYE » Mon Apr 16, 2012 4:05 pm
You will only lose your legs... It will be cool :P
alterego13
Postby alterego13 » Mon Apr 16, 2012 4:40 pm
Hehe..I get what you're saying.
Didnt say I am trying to cut corners for safety...was just asking if anyone had any experience with those jack stands. But your inputs are acknowledged :)
JoeJoe
Postby JoeJoe » Mon Apr 16, 2012 7:51 pm
my 2c worth..
I used the OEM Scissor Jack that comes with the car with SCA 3000kg Stands (on sale $30) under front both sides while doing front brake callipers..
http://www.supercheapauto.com.au/online ... escription
but never again, as very scary using a Sciccor Jack to its MAX limit so I'm saving for a good quality Trolly Jack like "Leg It" shows.
Moral of the story.....OVER engineer for god's sake... :shock:
VRX 18" GunMetal Mag Wheels (TBA)
Whiteline 24mm Rear Sway Bar & Front Strut Brace
Reverse camera & Painted red calipers (+5Kw)
Carbon fibre Dash, Trim & B pillars Wrapped
LED Parkers & interior lights
Bonnet Gas Struts
Greddy Exhaust (coming soon)
BC Racing Coilovers (coming soon)
alterego13
Postby alterego13 » Mon Apr 16, 2012 8:10 pm
So did you find the OEM jack 'unsafe'... But no problems with the stands I take it? Or would you just not use them Both(jack & SCA stands)? You're spot on to answering my query.
JoeJoe
Postby JoeJoe » Mon Apr 16, 2012 8:25 pm
YES = OEM jack feels 'unsafe' (emergency jack for break down's) tho I did get it high enough to temp so could get Stands under car..
SCA brand I dont have a problem with but I go for over the weight limits & now will get a Trolly jack for future work.
"Moral of the story.....OVER engineer for god's sake..."
I will be lowering springs soon so a Low Profile Trolly Jack is what I'm saving for ATM..
BTW i grew up with a trucker family and have seen a truck fall off a JACK with ME under part of it :-< So have the right Tool for the Job makes it easy & MORE SAFER...
alterego13
Postby alterego13 » Thu Apr 19, 2012 1:20 pm
Whats the minimum clearence required to get the jack under the car? Looking at borrowing a trolley jack from a friend.its minumim height is 140mm..(car is stock height)
Postby SAM-24A » Thu Apr 19, 2012 3:54 pm
@ Ravi ..... 140mm should fit under a stock height Lancer without any probs.
Sam.
alterego13
Postby alterego13 » Thu Apr 19, 2012 4:02 pm
Thanks Sam :)
Postby sleeper » Thu Apr 19, 2012 4:07 pm
why not ramps?, much easier imo.
Users browsing this forum: Bing [Bot] and 36 guests
