help with laptop via hdmi to tv
FL_BLUE_LANCER_09
Postby FL_BLUE_LANCER_09 » Thu Apr 26, 2012 9:52 pm
hi stacey do you need help fixing this problem. if you would like me to show you or need help solving this problem.
there is a program that i use to fix my customers computers /laptops that i can login in remotely and fix this.
go to google and search for TEAM VIEWER and download the windows version of the program
Cammo00
Postby Cammo00 » Thu Apr 26, 2012 9:54 pm
lol mind read.
Love That Car. (cj-blue)
FL_BLUE_LANCER_09
Postby FL_BLUE_LANCER_09 » Thu Apr 26, 2012 9:58 pm
stacey im ready to help
Chubb
Postby Chubb » Thu Apr 26, 2012 10:10 pm
Have you tried turning it off then back on again?
BlueWRX
Postby BlueWRX » Thu Apr 26, 2012 10:55 pm
Yes i have turned it on and off both laptop and tv.
My tv it always on HDMI as the PS3 is always in use as i do not have a antenna. and Yes i have changed to antenna to take it off the HMDI to see if there is any difference.
this is the only issue i have with the laptop last year it worked now it doesn't.
Since i have tried and everything possible it purely comes down to that its ****ed!
Nick07
Postby Nick07 » Thu Apr 26, 2012 11:30 pm
With the PS3 - what you are plugging in should be formatted to FAT32. Here's a great forum link that I found:
http://answers.yahoo.com/question/index ... 246AA8lZcx
BlueWRX
Postby BlueWRX » Fri Apr 27, 2012 2:39 pm
Nick07 wrote:With the PS3 - what you are plugging in should be formatted to FAT32. Heres a great forum link that I found: http://answers.yahoo.com/question/index ... 246AA8lZcx
Its got nothing to do with the PS3 but yes it is already formatted with FAT32.
This is purely trying to get my HP laptop to work on my LG tv VIA HMDI cable.
Dire
Postby Dire » Fri Apr 27, 2012 3:22 pm
Is it a full HD tv? It could be trying to display in a larger resolution or a different ratio to the tv.
Dire
Postby Dire » Fri Apr 27, 2012 3:23 pm
BlueWRX
Postby BlueWRX » Fri Apr 27, 2012 3:32 pm
Yup it is. Lol its worked before so i know there is some kind of tiny problem from the laptops end, so frustrating :(
Twellsy
Postby Twellsy » Fri Apr 27, 2012 3:36 pm
I use my dell laptop to watch movies on my plasma , but I don't use the HDMI cable I use a monitor cable ( blue square plugs ) and plug it into the PC port on the tv ( no formatting or anything need and quailty is still brillant )
BlueWRX
Postby BlueWRX » Fri Apr 27, 2012 3:40 pm
hmm monitor cable sounds interesting may do some research on that :)
Twellsy
Postby Twellsy » Fri Apr 27, 2012 3:46 pm
I just went to dicksmith and told them I wanted to run the laptop through the tv and they sold me a 10 metre cable ( just check the connections I think from memory both connectors need to be the same )
Got the longer cable so I can kick back on the lounge and surf the web on the 55 inch plasma :D
SEB15
Postby SEB15 » Fri Apr 27, 2012 3:51 pm
SEB15 wrote:Ok Make sure the tv is on HDMI 1,2,3 etc then Right click on your home screen---> select screen resolution-->On multiple displays select extend these displays--> Apply--> keep changes-->ok And youre done ( i hope) I have to do this every time when i connect my TV
Did you try this?
Tarquin
Postby Tarquin » Fri Apr 27, 2012 3:56 pm
Try having everything off, but connected.... Turn on the TV first to correct HDMI input.... Turn on Laptop....
This sometimes forces the port to activate correctly in clone mode to have the same image on laptop and HDMI...
I'm thinking that there might be an issue with either the HDMI port or the gfx card. Sometimes I've seen laptops stop clone mode from working... You should be able to Fn toggle the display to just display just via itself (no scoreen)
I'd also be at a point to forget the HDMI and just use a VGA cable with 3mm audio cable to the TV instead.
- CCJ Premium Member #0015.
Tarq's Paintshop
