Just wondering if this is legal, pretty sure its not just wanted to check though its a creative way to use it though I gotta admit
http://www.youtube.com/watch?v=xLbA08a7 ... el&list=UL
Plasti dip questions
- Platinum Ace
- Lancer Ralliart
- BUZZ_QWERTY
- BUZZ_QWERTY
damocr wrote:if i were to plastidip my wheels would the weight change the performance much or would it be so small that it becomes a non issue
The weight is negligible, however if you do plastidip - I recommend spraying them in the daylight and do nice thick coats. Otherwise you'll have something like my wheels which are a pretty shitty job (coats thick, but uneven).
- malkinfalcon
In regards to plastidipping wheels - http://clubcj.net/viewtopic.php?t=11603 ... dip+wheels
That can't be an ES !
damocr wrote:how long have you had your done for now dazz? would you recommend it, even as a temporary solution. powdercoating is just so expensive these days
8 months now. Of course, if you can powdercoat you should powdercoat. I only did it because of its reversibility (I just wanted to try the colour). For the first 2 months it was more or less awesome (nice matte black finish I'd been looking for). It doesn't come off as easy as some say.
I'd only use it as a temporary solution. I'm thinking of painting my wheels properly soon or atleast get new ones.
With all that said, I only have one problem with it which is that it loves to collect dirt and dust meaning you'll want to clean it regularly (I just use a pressure cleaner).
I sourced mine from Caswell Plating @ http://www.caswellplating.com.au/store/ ... on-coating and had it couriered up to Queensland.
- JohnoFrost
- Lancer Learner
richyo wrote:Plasti Dip doesnt come off easily at all! Plenty of videos on youtube with people high pressure washing their cars and even taking their whole plasti dipped car through drive through washers!
Mine came off easy as, I just sliced and pulled and it came off easy!
