	Aftermarket headlights questions...
Is 2008 Lancer VR headlights same as 2010-2012 Lancer?
						- ijustatecurry
I want to buy this ( http://www.ebay.com.au/itm/120938858887 ... 4845wt_908) but the ad said 2010-on, so not sure if it will fit 08 Lancer.
						joey0828 wrote:I want to buy this ( http://www.ebay.com.au/itm/120938858887 ... 4845wt_908) but the ad said 2010-on, so not sure if it will fit 08 Lancer.
I have these on my '10 lancer and they are a direct replacement. Perfect fitment. You will need different globes though from the stock HB4 to H7 for low beams. High beams are included and parkers are the led strips and halos
- squala
 - Post Monster
I took out the aftermarket bulbs off my 2009 Platinum and putting them on my current car without issues. And AFAIK, Mitsu has not designed different shape headlights for newer Lancers.
Ask the seller to explain why it would only fit 2010+ models and not older ones.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
						7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
- big_d
 - Lancer VR/GT
Sorry to hijack your thread, but I have a question about headlights also that may help answer why different headlight options exist.
My VRX has HID headlights as standard (NZ spec), as a factory feature these headlights have Adaptive Front Lighting or AFS (lights that come on when you turn a corner - see YouTube videos for reference) – so the inside lights are angled towards the outside of the car to make this work.
My question is, are there any aftermarket headlights that fit (and work with) the factory HID and AFS set-up?
[youtube]http://www.youtube.com/watch?v=7GMYt79xYbw[/youtube]
[youtube]http://www.youtube.com/watch?v=OnYyW2LHFXI[/youtube]
squala wrote:I took out the aftermarket bulbs off my 2009 Platinum and putting them on my current car without issues. And AFAIK, Mitsu has not designed different shape headlights for newer Lancers. Ask the seller to explain why it would only fit 2010+ models and not older ones.
I think the the factory who make this headlights mention it 2010-ON, so the seller have no idea what's different between 2007-2012 Lancer. They just follow what factory said.
