Help needed with foglight install
ok, cant say i have done one, but your idea sounds right do a button on the dash just to keep it clean, you could probably use that cable that runs into the fuse box and from what i hear the wiring looms dont change much at all so i believe you could and just find it in the fuse box than run it from there back to your dash for your switch, i wouldnt try and change the stalk it would be hell and not as cheap.... but its up to you, without seeing it tho i couldnt really be must help my friend sorry
himynameisdaniel
I can no longer see the ebay link.
however if they are OEM or genuine Mitsubishi Fog Lamps.
the following guide should be what you need...
https://docs.google.com/open?id=0B8y9I6 ... F9hblFvZmM
This is a scanned copy of the instructions including how to program the ecu to have fog lights. (you will need a MUT-III or go back dealer for this.)
himynameisdaniel
