transmission oil change
hi just want to know is it hard to do yourself and were do your check your oil level in a ralliart lancer ?
- zedd82
I haven't done a full change myself but it's not too hard. I would say if you can change your engine oil you should be able to change the SST fluid.
As they say, there is no way to know how much fluid is in the SST. You need to catch everything that comes out and measure it then replace it with the same amount again.
