OK so i know there are plenty of side mounting brackets on ebay and around that require 2 self tapping screws.
But i wanted to know if anyone has been able to successfully side mount their plate without damaging the bumper at all. ie not drilling into it.
Has anyone tried and failed as well. Just wanting to brainstorm.
Are there any adhesives on the market that would hold, or perhaps someone has made a bracket that extends upwards from the plastic surrounding of the fog lights?
Front Number Plate side mounted without screws??
I have used Velcro tabs that are sticky on the back side but my number plate is in the centre of the bar so the air pushes it against the bar. Mine has never come off when driving. Yours is mounted on the side so I would expect a lot more air pressure getting behind yours to blow it off. You can try it but be warned if it comes off you could damage the plate holder or even possible your paint or windscreen if it flies off.
Another option is to place strong magnets on the inside of the bar if you use a steel frame.
Good luck.
Good luck.
Has anyone used this before?
http://www.ebay.com.au/itm/20mm-3M-Auto ... 3f0487a5d7
think i might grab some and check how good the contact is
- chunky9
Yeah thats the stuff that most of the window visors are attached by. Should work fine
My progress thread: http://clubcj.net/viewtopic.php?t=13443
- Speedie
http://www.bellautomotive.com/License-P ... 6230-8.htm
http://www.rhdjapan.com/auto-select-num ... ount-60729
http://justjap.com/store/product.php?pr ... 262&page=1
http://www.grimmspeed.com/catalog/produ ... cts_id=226
couple of options out there but none for not putting holes in the bumper, but the grimmspeed might be able to mounted through the grill
- rokpapaziz
