Boost gauge install
Boost gauge install
Trying to install my mechanical Boost gauge but I cant figure out where is a good place for the hose to go through the firewall.. No idea what im doing! I want the gauge to sit on my dash on the right of my steering wheel.
Australia's sexiest blacked out ralliart
evo x turbo, ets intercooler, turbosmart wga, aem intake, ur intercooler piping, ur turbo back exhaust, 3port
Mitch ... you say
You really should plan & research such mods with other members who have done similar before you attempt them.
It helps prevent any unnecessary & unexpected dilemmas that might occur part way through the job ....
Try-It next time ....
Sam .....
Merlin Inspired Variable Engine Control
...."No idea what im doing!"
Sam .....
- bunnishiwa
Drilled a hole.... Brave man.
If you pull the carpet behind the accelerator pedal away you will see a grommet that goes into engine bay. Cut appropriate hole in grommet, feed tube through, put grommet back in (i used flat head screw driver). Feed tube to wherever and use cable ties in engine bay
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
- Lowered on Kings
- rokpapaziz
here
You can try here. Not sure if yours will have the lining that covers that area. Mine doesn't.
[b]
[b]Who is online
