Installed the lateral locks yesterday, and getting some squicky noise from it when turning or going over bumps slowly:/
Any ideas?
Rear sway bar lateral locks issue...
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
Are they moving? Do them up tighter
Did you clean the grease off the bar before you put them on?
If they're not moving then maybe they're just rubbing against the bearings? Theres not many things it could be...
Edit: On this topic; does anyone have a link to where I can get some?
You know what I mean mate.
If you not gonna help, don't bother commenting. Sick of smart ass comment on this forum.
Just need help with my car, not Dickie comments.
Dire, not sure man. Gonna either tighten it more or completely take it off.
Yeah thanks guys!
Found the problem..
The lateral lock spun around and was rubbing in the frame where the sway bar is connected to of the car.
Should do it up really tight then!
Found the problem..
Users browsing this forum: Google [Bot] and 24 guests
