EZ LIP - Universal Lip
Carl-BVI
Postby Carl-BVI » Thu Feb 28, 2013 9:31 pm
http://ezlip.com/
Got this product a couple of weeks ago! (For my sideskirts
Really accent's the skirts and makes the car look lower and with the flexible rubber it would protect it a bit to i guess!
Just thought id share (Will upload a picture asap)
-Carlos
Postby SIX » Thu Feb 28, 2013 9:36 pm
on of the other guys with the RA front has this , im thinking of putting it on mine now i have that lip to protect it a bit
Carl-BVI
Postby Carl-BVI » Thu Feb 28, 2013 9:40 pm
It would be good mate, VERY flexible. looks great to.
chunky9
Postby chunky9 » Thu Feb 28, 2013 9:41 pm
Yeah ive been considering doing my sides with this stuff. I saw it on a silver ra somewhere, thought I saved the pics, but yeah it finishes the sides nicely :)
Postby Mitch » Thu Feb 28, 2013 9:43 pm
once i get my front bar repaired i might get this too :-) damn good idea
Seal Cub
Postby Seal Cub » Thu Feb 28, 2013 10:35 pm
I posted this in another thread before, but looks like this is a good thread to share this.
Get one! It's an inexpensive solution for a lip and it really protected my bumper yesterday when I hit a deep driveway which I didn't see :(
Only minor scratches though!
Leez
Postby Leez » Fri Mar 01, 2013 12:55 am
Picturesssssssssssssssss
Platinum Ace
Postby Platinum Ace » Fri Mar 01, 2013 8:09 am
Iv got ez-lip front & sides on mine. Really good product as it does protect and gives the car a different look then your regular bumper. :D
abc88
Postby abc88 » Tue Aug 19, 2014 7:30 pm
About to order one myself, what's the longest you've had yours using only 3M tape?
Was the 230cm enough, assuming all of it was usable
Thanks
Zaphod
Postby Zaphod » Tue Aug 19, 2014 8:47 pm
Very, very old thread Pat - last post was 01/03/13
If you are going down that track, have a look at Rhino Lip; similar but stronger (and stiffer) - EZ-Lip is a foam structure with a smooth outer surface, Rhino Lip is solid all the way through.
The EZ-Lip is therefore more flexible, but tears more easily - the Rhino Lip won't tear, but it's harder to get around tight corners...!
abc88
Postby abc88 » Tue Aug 19, 2014 9:24 pm
Cheers mate, good advice :)
I was only leaning towards Ez lip because it could be stuck on. Didn't want to drill holes :D
Zaphod
Postby Zaphod » Wed Aug 20, 2014 5:51 am
You'll need to drill holes anyway - unless you're unbelievably lucky and never scrape a driveway or drive faster than 60km/h (don't forget that at high-speed, the air passing under your front bumper will try and peel the Ez-Lip down and off..).
You can just use self-tapping screws and wide (panel) washers th hold it all in place if/when it starts to peel.
Don't let me put you off, I'm going to do this on mine anyway, just as a 'scrape prevention'
abc88
Postby abc88 » Wed Aug 20, 2014 8:05 am
Sounds good $35 to prevent bumper damage. Was on the look out for lips which utilise the stock screw locations so could be held on without drilling and restuck on after it peels but doesn't seem like they make anything similar for the Cj.
Users browsing this forum: Google [Bot] and 42 guests
