Lazactiv_ - Introduction/Exhaust Help
Hi does any one know if a INJEN® SES1836TT - Axle-Back Exhaust System would fit a 2012 Mitsubishi lancer activ
if your build is after the change where the exhaust passes through the rear driver side control arm then no. if your before the change were it runs straight down the middle of the car to the larger type muffler then it will fit.
