Can someone please give instructions on how to remove the front interior reading lights the one just above the rear view mirror? I have this very annoying noise and I think I have narrowed it down to the Blue Tooth mic, which I don’t use as I have a separate one, but need to get the light out and don’t want to force it if there is an easy way. I did some searching but nothing comes up.
Many thanks.
How do I remove the front interior reading lights please?
- Dungogvolts
- rokpapaziz
rokpapaziz wrote:I pulled the whole assembly out with my finger tips. Just gently but firmly from the edge
yup. the whole unit comes out. Just pull it out, but not too hard, as you may start yanking on the cables.
- Dungogvolts
just use a thin screwdriver with something soft covering the top of it and place it between a gap and wedge it out, while you are at it replace your interior lights with 32mm 5050 leds
get a custom look
get a custom look
- Dungogvolts
yeah owners manual it :L took a while to find it though cause I'm terrible with manuals =="
+1
Damir wrote:just use a thin screwdriver with something soft covering the top of it and place it between a gap and wedge it out, while you are at it replace your interior lights with 32mm 5050 ledsget a custom look
+1
