Ive tried and tried but the log file i get out of it is rubbish. Ive gone over evoscan so many times my head hurts and cant work out whats wrong.
Need some one wh has abit of know how and can help me get a 3rd gear log so i can give it to beeble
I can meet you... prefer some on on southside but i will travel
Need some one to Log my ecu
- bunnishiwa
Have you tried downloading the standalone log file for your ROM off goldenevo and trying it with just the tactrix?
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
- Lowered on Kings
- bunnishiwa
I don't mean an actual flash file. www.goldenevo.com find your ROM id, either by description of year etc (eg i have AUD 2011 RA, which is 5965006) or by rom id if you already know it. From there you can download the correct file for Evoscan, and also a file for standalone logging. If ecoscan still no good try putting the logfile onto the tactrix and go for a run with just tactrix plugged in. Then check csv files created after for data.
Apologies if you've tried these
- Lowered on Kings
- Lowered on Kings
mode32 is enabled. Beeble has done the tune iam just doing the logging.
Were trying Rax logging now
How do i load the .xml def files into evoscan
- bunnishiwa
There are instructions on goldens site re where to save the evoscan settings.
- Lowered on Kings
- Lowered on Kings
You mentioned rax fast logging? That also needs the rom to be patched before working. If Beeble patched ur rom with Richardjh's fast logging, u should be able to use rax logging. Should check with Beeble with what to log
- GST basemap
- AMS boostpill
- Evo X BPV
- UR UICP
- AMS boostpill
- Evo X BPV
- UR UICP
