Will Brembo Evo X Brakes fit a normal Lancer ?
All Brake Modifications.
denzza
Postby denzza » Sun Aug 18, 2013 2:26 pm
Hey guys!
Dont know if this has been discussed already but i couldnt find anything on here.
I was just wondering if the EVO X brakes fit the lancer? Plug and play, or would their have to be any modifications made ?
By Brakes, i mean the caliper and rotors :)
Also the RA brakes, will they fit the normal lancer without modifications.
Thanks guys!
FULL EVO X TURBO SETUP
BC RACING BR COILOVERS
Jason-VR
Postby Jason-VR » Sun Aug 18, 2013 2:49 pm
Es/vr, vrx and ralliart brakes are all bolt on or plug and play if you like.
EVO brakes do not fit straight on.
The best cheapest and easiest brake upgrades would be to fit VRX rear brakes and Ralliart front brakes.
denzza
Postby denzza » Sun Aug 18, 2013 2:53 pm
hmm i see!
Why vrx on the rears ? can i just get the whole RA set up ?
And would you know what modifications are needed for the evo x brakes ?
Thanks!
Jason-VR
Postby Jason-VR » Sun Aug 18, 2013 2:59 pm
The Ralliart rear brakes are different because they have the drive shafts going through them. VRX are slightly bigger then es/vr rear brakes. It is up to you to work out if upgrading the rear is worth the cost when the front do 75% of the braking.
zedd82
Postby zedd82 » Sun Aug 18, 2013 3:31 pm
Evo X Brembos will fit on the front and rear of and RA with a few extra parts and a couple of minor modifications, but I can say for sure if they will fit on the NA Lancers. Maybe PM Speedie as he is doing the mod to his RA and might be able to help you out.
denzza
Postby denzza » Sun Aug 18, 2013 4:05 pm
Hmm, i think i might do the RA upgrade instead.
I can get the RA whole brakes with rotors, pads, and calipers. for $450.
So the rear rotors would be useful ?
Is the RA brakes a single piston still ?
Thanks guys!
poe_sniper
Postby poe_sniper » Sun Aug 18, 2013 5:15 pm
Single piston rear.
Jason-VR
Postby Jason-VR » Sun Aug 18, 2013 5:17 pm
Fortitude wrote:The Ralliart and VRX brakes are twin piston in the front. Dont know about the rear.
This is incorrect.
They both have 294mm disc but different offset.
The VRX have single piston calipers with from memory around 55mm piston.
The Ralliart have twin piston calipers.
Jason-VR
Postby Jason-VR » Sun Aug 18, 2013 5:24 pm
They both bolt straight on but you will need the complete brakes including discs and calipers. The Ralliart has different hose to yours and VRX too.
denzza
Postby denzza » Sun Aug 18, 2013 5:45 pm
So should i get braided lines for a RA and it will fit into these brakes ?
Thanks for clarifying that up guys! i think i might go to the RA brakes due to it being twin piston.
rokpapaziz
Postby rokpapaziz » Sun Aug 18, 2013 6:00 pm
denzza wrote:So should i get braided lines for a RA and it will fit into these brakes ? Thanks for clarifying that up guys! i think i might go to the RA brakes due to it being twin piston.
If you're not in a rush, there will be a few parts floating around in the near future that will help you.
RyanMK
Postby RyanMK » Sun Aug 18, 2013 6:28 pm
I've got RA front calipers with HEL braided lines. It's a direct bolt on. Didn't see the point upgrading the rears being a FWD.
Return to “Brakes”
