Hi Guys,
If any1 has either a plastic or CF evo x front nose grill and wants to get rid of it let me know please.
WTB: Evo X front Nose Grill thingy
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
yeah i have found rainbow pen and ARS bodykits on fb
id rarther go on ebay or something with some buyer protection.
DBA Extreme Pads
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
hey kevin that one looks pretty cool
problem is that one covers up the tow point in the front
ive seen others that actually have a cut out for the tow hook.
its so hard to find one for the RA
DBA Extreme Pads
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
Yujin I think I'm going to go for the ars one its alot cheaper and matches the oem plastic look
DBA Extreme Pads
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
Hahaha! im sure we will be fine, after i get that im gana look for a bracket for the number plate.
im not worried about cutting into the bumper cause that bumper is now a stanard bar for other cars and the centre part is easy to replace, its drilling into it for the number plate that im worried about. once that hole is there its there for good.
DBA Extreme Pads
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
not 100% sure on that one, im pretty sure ive seen pics of bars with no middle section that look like RA ones.
but even if you do cut the front out it still looks oem, and you can always put the number plate over it , but like i said b4 if you drill into the bumper then its all over red rover as they say
DBA Extreme Pads
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
i attached a number plate bracket with double sided tape? I've had it on for a good 4-5 months and no issues. then if u want u can drill the actual bracket so u can puts the screws in for the plate.
Also are u buying some sort of grill mesh to put behind the evo x nose or are you leaving it ? any ideas on what to buy?
really? iave heard that suff doesnt hold on on that well. i saw on a forum not that long ago some1 had a diy on how to install it without drilling.
im not gana put any mesh on it, im just gana spray the inside black, if it looks bad then ill try get some mesh but all the pics online ive seen are good without mesh.
DBA Extreme Pads
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
