Hes tuned a lot of people's cars... Try the search bar.
Haven't seen any negative feedback so far.
Anyone Know merlin ECU tuning ?
Like Jake said, please use the search bar in the future.
He has tuned my car as well, would definitely recommend it once you have done exhaust/headers/intake
He's worked on my car too - naturally aspirated like yours. Just remember to do any physical/mechanical mods BEFORE you do the tune.
I couldn't recommend him enough; his work is exceptional and I've noticed a big improvement in responsiveness, acceleration, and fuel economy.
2.0L - K&N Typhoon SRI - High-Flow Exhaust System - Merlinised
- Speedie
There was a member here who paid over $1500 for his NA lancer to be tuned on a dyno, the result was almost the same as a Merlin tune. Without spending big money doing over the top mods (engine displacement, throttle body boring etc) its the best way to go.
- Zaphod
merlin wrote:For bigger top end power gains you would need to either run e85 and/or add a set of decent cams. Either of those are doable. Or, go mad like Ben and add a turbo - that wakes them up all right!
Dave, on an NA, does the usual RA snorkel, panel-filter swap and a cat-back exhaust make any real difference? (assuming a tune thereafter).
I'm hoping you say yes, but want to hear the expert opinion...
Cheers!
Zaphod, those are the best mods, and really the only mods you should bother to make, unless going nutso.
These cars do respond VERY well to a 200 cell CAT and exhaust.
The stock headers are ok so not a huge gain by upgrading them.
The Ralliart intake snorkle is a good mod, with a good panel filter, like a Cosworth (blue) or a Ralliart (red) if you can find one and afford it.
But the stock panel filter is pretty good as is.
I would not recommend the K&N panel filter.
The green HKS panel filter is good too, for tarmac use, I would not recommend it for dirt road use.
There are a few other tricks that I point out on tune day too.
