Car Battery starting to fail ???
gman90
Postby gman90 » Sun Jul 06, 2014 9:55 am
Hi can some tell me if there are any issuies when changing car battery like losing preset radio stations and other stuff or are there no real probs???? I am going with a
Century Ultra Hi Performance Battery
Product Name NS70LX
Product ID 122108
Would this be a good choise for Evo X
Thx Gazza :?: :?:
shamoo
Postby shamoo » Sun Jul 06, 2014 10:19 am
Hey
Yeah cos you are disconnecting the battery you will loose the radio stations and the clock will reset.
As for battery choice for the evo...sorry I cant help there.
gman90
Postby gman90 » Sun Jul 06, 2014 10:53 am
Thanks ,What are other people using (battery )???
Gazza
Jason-VR
Postby Jason-VR » Sun Jul 06, 2014 3:17 pm
Before you disconnect your battery to put your new battery in use jumper leads to another battery so your car does not loose power then you won't have to reprogram your radio channels again.
Toybox
Postby Toybox » Sun Jul 06, 2014 3:41 pm
Battery spec is fine beside that its not 100% maintenance free with the battery located in the boot.
And anything electrical that has a memory eg defi control unit, radio stations, cluster K's trip unit etc will reset.
The worse case scenario when changing battery is you blown one/few fuse.
As for battery choice, unless u dont mind topping up with water/acid from time to time, try find a 100% maintenance free. Will be more pricey though
gman90
Postby gman90 » Sun Jul 06, 2014 3:45 pm
Hi thanks everyone for the feed back Gazza :D
Kal777
Postby Kal777 » Sun Jul 06, 2014 5:08 pm
battery is located in the boot. needs to be a sealed battery for safety and roadworthy reasons. lead acid or "wet" type batteries (any battery where the cells are accessible should not be used inside the cabin of a car/caravan as they release poisonous gases.
Speedie
Postby Speedie » Sun Jul 06, 2014 8:40 pm
Get the battery shop to change it, most have a battery the plug into the cigeratte lighter to keep all presets
Return to “Electrical”
Users browsing this forum: Bing [Bot] and 9 guests
