How to get caliper bolts off?
Anyone have any tips on getting the caliper mounting bolts off? Just can't seem to get enough leverage to unbolt them.
himynameisdaniel
If your rotors\pads have not been serviced since brand new. you will find that Mitsubishi has used a form of thread lock from factory. this will become evident when you finally take the bolt off you may see some dry red paste on the threads.
best thing is shop air.
otherwise you will need massive amounts of torque and penetrating oils.
I came pretty close to stripping a bolt. I thought I had it and then somehow went on a bit of an angle and whoops.
I'll replace it next time..
- lantourismo
himynameisdaniel wrote:If your rotorspads have not been serviced since brand new. you will find that Mitsubishi has used a form of thread lock from factory. this will become evident when you finally take the bolt off you may see some dry red paste on the threads. best thing is shop air. otherwise you will need massive amounts of torque and penetrating oils. I came pretty close to stripping a bolt. I thought I had it and then somehow went on a bit of an angle and whoops. Ill replace it next time..
Thanks for that info It will come in handy
