Rattling Noise I think
raidmaster212
Postby raidmaster212 » Sat Apr 27, 2013 10:58 am
hey champ sorry for the delay. um yeah after they had a look at it at the service centre i took it to i left it there for a day or two and they sorted it all out. been smooth ever since
Roadtrain
Postby Roadtrain » Wed Aug 20, 2014 7:32 pm
my car has been doing this for 2 days, i'm a second owner had the car 2 months, were you covered under warranty or did you pay? if so how much were you looking at?
mine is really noticeable especially one in 6th revs normal then low then normal then low.
Port Macquarie Ralliarts
rokpapaziz
Postby rokpapaziz » Wed Aug 20, 2014 9:44 pm
Any of you guys running the Super Sport flash? After I did mine I noticed it would not change into 6th gear at 60km's anymore in auto mode.
If I change it manually it sort of grinds, so I drive in 5th gear at 60km now.
I'm suspecting that's what killed the early model SST's in RA's.
Any how a fluid change at around 45,000km is what is in the service manual these days, my original gearbox was replaced at 75,000km. It was stock back then
Roadtrain
Postby Roadtrain » Wed Aug 20, 2014 9:50 pm
Nope mine is stock.
rokpapaziz
Postby rokpapaziz » Wed Aug 20, 2014 9:53 pm
I was covered under warranty thankfully, my new gearbox has been trouble free so far.
I would probably suggest getting the fluid changed. Unfortunately you are probably out of warranty now being an 08
Roadtrain
Postby Roadtrain » Thu Aug 21, 2014 4:13 pm
yes the clutch slip issue, woke up this morning to find car wont start, have Pete coming over now to have a look, hoping issues are not related.
thanks for that info guys, so definitely a Mitsubishi dealer for this?
rokpapaziz
Postby rokpapaziz » Thu Aug 21, 2014 4:30 pm
changing the fluid in the SST is probably not that difficult if your handy enough. You will want to change the external filter too.
Changing the internal filter is a good idea, but is hard.
There's a few threads on the US forums on how to do it
BST50N
Postby BST50N » Thu Aug 21, 2014 4:44 pm
If you're out of warranty it will be an exxy job if they have to pull the tranny. Try new fluid and filter first - Ford, Diaqueen or Castrol Tranmax Dual - all the same. Ford and Castrol much cheaper. If that helps, then winning. You could also do teach-in using Pass-Thru CAN. I did this after doing the s-sport flash and it reduced a similar issue I had. Never heard grinding, but my exhaust it to loud!
Return to “Maintenance”
Users browsing this forum: Google [Bot] and 18 guests
