I topped mine up before going down to Wakefield on Saturday with Castrol Power Steering Fluid I picked up from Supercheap for $7.49 for 500ml
Going by the MSDS it's recommended for use with Mitsubishi Power steering fluid
http://msdspds.castrol.com/bpglis/Fusio ... 013-11.pdf
So far no problems with it.
scott_drake
scott_drake
the oem fluid is much thicker and more stable at higher temps compared to non oem fluids. Castrol, Amsoil, Penrite, Nulon where like water consistency compared to oem
The closest aftermarket one that came close to oem specs was Motul Dexron 3 which you can get though autobarn.
But hey, a new power steering pump is only a couple of hundered dollars
.jpg)
