Im trying to build a frankenstein CJ pretty much. I currently have an ES, and want the best of all worlds.
In a perfect world i want a 2.4L turbo AWD variant. Basically a raliart reshelled into my ES, but the problem with that is the RA only came in SST. I want a manual plain and simple or its a no go. So basically now an Evo X into an ES. kind of.
The few questions i have are as follows:
1) the differences between the 4b11 evo x engine and the 4b12. I ask because the way i have to do the above mentioned is to bolt an evo x manual box to a 4b12, as i cannot bolt up a manual RA box obviously.
2) difference in the evo x manual and the RA SST with regards to where everything comes out. My concern here is the chassis tunnel, if the evo X is much wider/offset a fraction etc to accomodate for the different running gear/custom prop shaft made etc etc.
3) will an RA end bolt straight up to another FWD CY4A chassis if i make the necessary mounting points - basically if i can just bolt in an RA rear cradle if i drill out the mounting points.
In an ideal world i can just buy a VRX motor, evo box and RA rear end, and bolt them all up with little modifications, but its probably not going to be that easy. That being said, working in my job and the facilities at my disposal i can probably do this a hell of a lot cheaper than most others, the main reason being i dont just go out and buy an evo. I dont have 20k + lying around. Ive spotted an engine for 650, box for 500, complete rear cradle for 350 and already thats most of big bits for peanuts.
Anyway, without boring you all further, i would love the following if people can provide photos and some brief measurements:
4B12 motor from gearbox side with flywheel in and bell housing bolt holes visible.
4B11 (preferrably evo variant if it is any different) motor from gearbox side with flywheel in and bell housing bolt holes visible.
Evo manual gearbox from motor side, with bolt holes visible - and from the rear.
Regular CY4A manual box (i understand all CY's use the same box) from the motor side with bolt holes visible
So please, if you have any of those out/lying around/old photos etc and can take a quick snap, or possibly even get a few measurements (as i doubt anyone has actually tried or successfully done this before) then i can get a good idea whether or not it is worth it (as anything is possible with enough cash thrown at it lol)
The other route, if it is not possible, is the same thing but just FWD (
The other benefit here i guess, is if this proves successful, is that people will be able to manual convert their rallarts - if they want to go down such a route after their warranties are over
