hey guys,
just got quoted $1600 for a new timing chain?
is that normal has anyone done it before and how much did they pay?
I'm in no way going to pay that much for it, please help!!
	Ralliart Timing Chain???
the full Timing chain kit
Timing Chain Kit all OEM parts $518.00
1035A583 GASKET,ROCKER COVER
1052A149 OIL SEAL,CRANKSHAFT,FR
1140A073 CHAIN,VALVE TIMING (NEW)
MN183894 TENSIONER,TIMING CHAIN
1141A004 GUIDE,TIMING CHAIN TENSION SIDE
MN183892 GUIDE,TIMING CHAIN LOOSE SIDE
MN183896 CHAIN,ENG OIL PUMP DRIVE
MN183897 GUIDE,BALANCER TIMING CHAIN
MN183898 TENSIONER,ENG OIL PUMP CHAIN
MD356000 OIL FILTER
MD050317 SUMP PLUG GASKET
MD356000 OIL FILTER
Parts are $518, and i got quoted by mitsu here @ $800 mark just for the labor and they never done one so is a NO, NO for me, but that is another story, but again this is Mackay where all the prices are up to the roof. i would say to shop around and than compare. Maybe the best way is to supply the parts and pay just for labor.
What year model is yours? and do you have and warnings on the dash? or you want to change it just for a piece of mind?
SEB
SEB
Just want to put it out there again, a month after buying my 09 Ralliart (privately) my timing chain went, put the pistons through with ZERO warning and cost me $5000 and 3 weeks without my car to get it all fixed through Mitsubishi.
Don't leave this, if you are being told there is an issue then get it sorted ASAP.
Port Macquarie Ralliarts
