	Custom DRL - Am I too Blingy?
I've seen the ones that replace the fogs around $400 on eBay but apparently it's plug in a play so a simple DIY install.
Like I said there are some cheap ($125) ones from China, shorter and the are designed to fit along side the fogs but are shorter.
I wouldn't mind the type that are built into the headlight as long as they can be wired so they come on automatically and turn off when your headlights come on, just like proper DRLs are meant to.
Mine activate as soon as you turn power on. Dim when the headlights come on.
Yeah i looked at those chinese ones and they are good for lancers. Not for evos.
If it replaces you fog light how is it plug and play? Fog lights dont turn on unless you switch them on. Unless you need to use the wiring to activate it. Even then might need cut and soldering. I prefer to keep my foggies during winter driving.
Switchbacks, three wire bulb replacement that are normally LED. Come on as either DRL or parker as white, then blink when using indicators. (depending on how you wire it up)
Replaces the front indicator bulbs =)
Been looking at them for mine too. Easy 'DRL' option.
~2009 Lancer RA Sportback~
~Mods: Custom intake, TD05, TurboSmart Kompact BOV, Hyperflow 100cell Cat, Hyperflow catback exhaust and upgrade IC, 2.5" IC piping kit, GS 3-Port, NA AUtosport Dyno Tune, Optima Redtop in the boot, Koya Racing SF01 18x9 +35, BC BR Coilovers, EvolutionX Designs Coilcover~
- Bigdamos
Amber and white LED's on the same light. Have a look at the link, this is one version of the lights. There are so many different types though. http://www.vleds.com/v3-wa-5k.html
I want something like this, as long as they can be wired up correctly.
http://www.ebay.com.au/itm/2007-2015-CJ ... 1c4c52a429
These look pretty good, just concerned they might be crap and not bright enough.
http://www.ebay.com.au/itm/LED-Daytime- ... 43d402dcce
Bigdamos wrote:Amber and white LEDs on the same light. Have a look at the link, this is one version of the lights. There are so many different types though. http://www.vleds.com/v3-wa-5k.html
Sorry to sound dumb but do these ones replace the normal CJ headlight indicators with a DRL type light that is on all the time but switched to amber when turning?
