Hi Guys/Gals
I have a quick question about a really loud rattle I get at low revs, it happens in all gears. almost sounds like the exhaust is rattling on the body ( I have checked this it doesn't appear to be )
Has anyone else had this problem or something similar ?
Just wanted to get opinions and thoughts before I take it in to be looked at.
The car is a NA 2010 lancer sx ( only mods air filter and RA intake, 2 years ago )
Cheers Twellsy
Loud rattle at low revs ( in every gear )
Manual? Or auto?
230kw/430nm @ 24psi on E85
12.191 @ 108.81mph - Fastest stock turbo ralliart in Australia
www.facebook.com/BoostinJuiceTuningSydney
www.clubcj.net/viewtopic.php?p=369141#369141
Can you feel the rattle at all?
Have you had the clutch touched at all recently?
Could be a number of things:
- Flywheel rattling (unlikely)
- Engine mounts
- Exhaust heat shield
Try and get someone to help emulate the noise while you can walk around the car and check under the car to pinpoint it.
- Engine mounts
